Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
st lights
Old Aug 13, 2014 | 08:55 PM
sumo's Avatar
sumo
Default st lights
hi, can any one help I have a st17 on a 03 every time I press the brake the front side lights come on and the dash lights flicker any one have a clue thanks
Old Aug 13, 2014 | 09:00 PM
RichieST's Avatar
RichieST
You've either got the wrong tail/brake light bulb fitted, or the bulb holder is all corroded up.
Change both the tail light bulbs for correct double filament ones and it'll cure it.
The flickering is quite common on ST170s, just turn the brightness of the dials down a bit and it shouldn't do it.
Steve Escos
Oct 1, 2015 06:57 AM
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
