Series 1 Rs Tubo PLEASE PLEASE HELP!
Old Aug 6, 2014 | 06:59 PM
fatty's Avatar
fatty
Default Series 1 Rs Tubo PLEASE PLEASE HELP!
hello ,
I apologise in advance for another ' its cutting out ' problem but i'm up against it now..
long story short...
86' S1 been rebuilt , standard ecu's , new dizzy , leads , was starting and driving but now it cuts out after 1 - 10 minutes and its getting worse.
Fuel relay - checked / replaced
12v straight to coil - still cuts out .
Boost hoses etc all seem tight - no air leaks
Put on standard breather system after rebuild..could be blocked pipe ?
SEEMS to happen when the clutch pedal is pressed...
Please can someone help as im getting desperate.. i can provide more details if required.
Many thanks ,.. Pete
Old Aug 6, 2014 | 07:20 PM
mercury grey minter's Avatar
mercury grey minter
Sounds like it needs setting up properly.Had the same problem with my series 2.Needed the fuel metering unit setting up.JAMSPORT did mine £80 rolling for a road session.
Old Aug 6, 2014 | 07:29 PM
fatty's Avatar
fatty
thanks for the reply.
i guess it could be that its just odd that its a straight cut almost like the ignition is cut too it.. then it starts up again.
It was running for longer periods before. Did yours literally just stop aswell ?
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
Bransby
Sep 11, 2015 01:09 AM
