wiring loom demons
Old Aug 3, 2014 | 09:22 PM
Jay's 3-door's Avatar
Jay's 3-door
Default wiring loom demons
Ok people bit of help required here please as my electrical knowledge is limited
Car - 1986 3dr sierra cosworth
Currently going through wiring loom before it gets put into car after restoration and have come across this
First picture is of a relay causing my headaches at the moment, I have no idea what its meant to control as searching on the internet just brings up all sorts, 2 of the wires out of it seem to be melted together so at some point theres been a major electrical fault, can anyone point me in right direction as to what these wires are controlling at all
Picture 1 - the relay in question
Picture 2 - the 5 wires going to this relay
Picture 3 - damage to the yellow and brown wires along full length between relay and connections
Picture 4 - this is other end of yellow wire going into the connection
Picture 5 - full picture of the yellow wires connection
Picture 6 - where the yellow wire ends after being followed past the connection, the length of wire after the connection appears undamaged (ignition?)
Picture 7 - this is where the damaged brown wire leads to, also first of the undamaged brown/black wires ends up here
Picture 8 - 2nd undamaged brown/black wire from relay ends up here
Picture 9 - the 3rd undamaged brown/black wire finishes here (abs?) This uses the same pin from the relay block as picture 8 and can be seen exiting the relay block on the right hand side of picture 2
Does anyone have any ideas on what these wires actually are and what could of caused the short, also where can I get hold of replacement connections
Any help appreciated thanks
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Aug 10, 2014 | 10:20 AM
opposite lock's Avatar
opposite lock
http://www.bigturbo.co.uk/
goto wiring section and see where the 5 wire colurs are , you can use as reference.
the yellow wire maybe 12v live from battery, ignition live or an earth .
going by piccys I'll take a guess its ignition live wire.
Old Oct 19, 2014 | 03:26 PM
Jay's 3-door
turned out to be something to do with the abs system after finding a wiring diagram, cheers
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
muz
Sep 30, 2015 08:29 AM
IainRS1700T
Sep 25, 2015 06:44 AM
