cosworth wiring loom demons
Old Aug 3, 2014 | 02:42 PM
Jay's 3-door's Avatar
Jay's 3-door
Default cosworth wiring loom demons
Ok people bit of help required here please as my electrical knowledge is limited
Car - 1986 3dr sierra cosworth
Currently going through wiring loom before it gets put into car after restoration and have come across this
First picture is of a relay causing my headaches at the moment, I have no idea what its meant to control as searching on the internet just brings up all sorts, 2 of the wires out of it seem to be melted together so at some point theres been a major electrical fault, can anyone point me in right direction as to what these wires are controlling at all
Picture 1 - the relay in question
Picture 2 - the 5 wires going to this relay
Picture 3 - damage to the yellow and brown wires along full length between relay and connections
Picture 4 - this is other end of yellow wire going into the connection
Picture 5 - full picture of the yellow wires connection
Picture 6 - where the yellow wire ends after being followed past the connection, the length of wire after the connection appears undamaged (ignition?)
Picture 7 - this is where the damaged brown wire leads to, also first of the undamaged brown/black wires ends up here
Picture 8 - 2nd undamaged brown/black wire from relay ends up here
Picture 9 - the 3rd undamaged brown/black wire finishes here (abs?) This uses the same pin from the relay block as picture 8 and can be seen exiting the relay block on the right hand side of picture 2
Does anyone have any ideas on what these wires actually are and what could of caused the short, also where can I get hold of replacement connections
Any help appreciated thanks
Old Aug 6, 2014 | 08:50 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Have you followed the wire to the ecu plug connection and found out which one it is IAW the diagram???
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
big_Rad
Sep 15, 2017 09:36 AM
jay030787
Sep 18, 2015 07:34 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
jdsjojo
Aug 1, 2015 08:50 PM
