efi turbo tps issue
Old Jul 31, 2014 | 05:18 PM
blackbeautyzetec's Avatar
blackbeautyzetec
Default efi turbo tps issue
Cant get my efi turbo in my s2 to start unless I unplug the tps sensor!
Its got the correct volts going to it. Tried another tps..icv...and injector loom but still the same issue.
Anyone know whats going on?
Old Aug 7, 2014 | 07:03 PM
blackbeautyzetec
Also tried another ecu
Old Aug 13, 2014 | 09:48 PM
Red_bull's Avatar
Red_bull
Ground issue maybe. I would check ground voltages. Maybe some ground pin gets +5v due to incorrect wiring
Old Aug 13, 2014 | 10:37 PM
blackbeautyzetec
Cheers, will check. Only has 2 grounds. 1 for the ecu and 1 for the edis. Will check anyway
Old Aug 13, 2014 | 10:39 PM
blackbeautyzetec
On the plugs. Gotcha
Old Aug 14, 2014 | 08:07 AM
Red_bull's Avatar
Red_bull
So you solved it?
Old Aug 14, 2014 | 12:52 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If you've tried good known working parts then it points to a loom/wiring issue.
If you know anyone with an OFAM ECU you could plug that in and at least be able to see what's going on, what sensors are working and test all outputs, etc.
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
muffster
13
Sep 3, 2015 09:40 PM
s1turboman
Aug 29, 2015 04:27 PM
marky_g
Aug 17, 2015 12:21 PM
