Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
alternator
Old Jul 24, 2014 | 08:54 PM
ytre's Avatar
ytre
Default alternator
Hello all, The radiator hose that runs from the bottom of the radiator to underneath the alternator on my 08 1.4 fiesta has wore through after rubbing against the power steering pipe I cant get near the spring clip underneath the alternator to let the hose off.
what do I need to do to remove the alternator?
Thanks in advance all
Old Jul 24, 2014 | 09:32 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
I usually use long nosed pliers or adjustable water pump pliers,
but if its impossible with the tools you have,
you have no choice but to remove alternator
draw a diagram for the alternator belt for re-fitting
Old Jul 25, 2014 | 06:14 AM
ytre's Avatar
ytre
thanks mk2, theres no tensioner on my fiesta, do the bolt and nut above the alternator tension the belt?
Old Jul 25, 2014 | 12:20 PM
mk2grp1's Avatar
mk2grp1
if there is no tensioner the long belt will be tensioned via a tensioning pulley.
some have a bolt that you attach a spanner or wrench to, and allow the tension on belt to slacken , they do spring back quite fiercely so watch out,
as mentioned draw a diagram for belt routing,
jonfoc
16
Sep 11, 2018 05:35 PM
steve.rst
Mar 15, 2016 08:01 AM
timsrs
22
Sep 24, 2015 08:14 PM
jay030787
Sep 18, 2015 04:38 PM
benw456
Sep 16, 2015 05:27 PM
