Cosworth parts. Some goodies :)
Engine bits:
Small turbo Escort Cosworth inlet manifold. Good to flow up to 600 bhp - Offers
OMP strut brace
Oil separator tank
Oil breather
Samco boost hoses
Group A coil
Yellow injectors
Crankshaft pulley
Stainless amal valve cover
Stainless actuator cover
2WD fast road clutch
Clutch ratchet
2 x amal valves
Standard MAP sensor
Crankshaft position sensor
Distributor phase sensor
Air change temperature sensor
Coolant temperature sensor
10 x random relays
Body parts:
4 diamond cut RS7 centre caps
Full set of outer window rubbers
Front fog lights
3 x fog light surrounds
Front indicator no glass
2 x full set of door trims including wing pieces, very rare
Interior bits:
3 door Sierra Cosworth clocks
2 x electric window switches
Rear electric window switches
Heated front windscreen switch
Rear windscreen switch
Front fog light switch
Rear fog light switch
Wiper speed switch
Dash light dinner switch
Steering column
Full radio aerial
Contact anytime at 00353873600160 or on here.
Can bring to Ford Fair if needed.
Cheers,
Philip.
Engine bits:
Small turbo Escort Cosworth inlet manifold. Good to flow up to 600 bhp - 400 as not pushed on selling this one
OMP strut brace - 75
Oil separator tank - 75
Oil breather - 25
Samco boost hoses - 25
Group A coil - 15
Yellow injectors - 40
Crankshaft pulley - 40
Stainless amal valve cover - SOLD
Stainless actuator cover - 25
2WD fast road clutch - 100
Clutch ratchet - 5
2 x amal valves - 30 each
Standard MAP sensor - 20
Crankshaft position sensor - 10
Distributor phase sensor - 10
Air change temperature sensor - 10
Coolant temperature sensor - 10
10 x random relays - 1 each
Body parts:
4 diamond cut RS7 centre caps - 50
Full set of outer window rubbers - 100
Front fog lights - 50
3 x fog light surrounds - 60
Front indicator no glass - 5
2 x full set of door trims including wing pieces, very rare - 150
Interior bits:
3 door Sierra Cosworth clocks - 150
2 x electric window switches - 25 each
Rear electric window switches - 5 each
Heated front windscreen switch - 5
Rear windscreen switch - 5
Front fog light switch - 5
Rear fog light switch - 5
Wiper speed switch - 5
Dash light dinner switch - 5
Steering column - 15
Full radio aerial - 5
Cheers,
Philip.
Oil breather - 25
Group A coil - 15
Clutch ratchet - 5
Body parts:
Interior bits:
Cheers,
Philip.
Sorry mate window rubbers are gone as are door mouldings and a few more bits.
Updated ad here:
http://cars.donedeal.ie/carparts-for...-parts/7354697
Updated ad here:
Prices dropped.
Description
NEED EVERYTHING GONE ASAP.
Small turbo Escort Cosworth inlet manifold - 200
2WD exhaust manifold complete - 100
2WD fast road clutch - 40
Yellow injectors - 20
Crankshaft pulley - 20
Stainless actuator cover - 20
2 x amal valves - 20 each
Oil breather - 15
Samco boost hoses - 15
Engine sensors - 5 each
10 x random relays - 5
Body parts:
Full set of smoked rear lights, clear repeaters and indicators - 50
Interior bits:
3 door Sierra Cosworth clocks - 100
2 x electric window switches - 20 each
Steering column - 10
Dash light dimmer switch - 5
Contact anytime at 00353873600160.
Description
Oil breather - 15
Body parts:
Interior bits:
BRAND NEW Light green injectors
BRAND NEW X 2: -31 actuator
BRAND NEW Cometic head gasket
BRAND NEW Samco hoses 2WD Cosworth
BRAND NEW piston dump valve
BRAND NEW X 10 Head bolts
BRAND NEW Sump gasket set 2WD Cosworth
BRAND NEW ARP conrod bolts
Stainless cam cover
Stainless Oil breather
Stainless Oil catch tank
Stainless Swirlpot
HT motorsport leads
Cheers,
Philip.
Stainless cam cover
Stainless Swirlpot
HT motorsport leads
Cheers,
Philip.
BRAND NEW Light green injectors 160
BRAND NEW ARP conrod bolts - 100
BRAND NEW X 2: -31 actuator 100 each
BRAND NEW Cometic head gasket 80
BRAND NEW piston dump valve 80
BRAND NEW X 10 Head bolts 40
BRAND NEW Sump gasket set 2WD Cosworth 40
Stainless cam cover 100
Stainless Oil catch tank 100
Stainless Oil breather 80
Stainless Swirlpot 80
HT motorsport leads 80
More parts available just ask.
Cheers,
Philip.
Cheers,
Philip.
Adam Graham
Sep 6, 2015 06:04 AM
