Brake upgrade reccomends plz
Old Jul 21, 2014 | 02:45 PM
Old ford's Avatar
Old ford
Default Brake upgrade reccomends plz
After doing the track day at the national day yesterday I am happy at the moment with the power but realised the stopping power is not really up to it I have 17 " 7 spokes on at the moment but going to look at getting some rims & tyres just for the track as I have made a mess of one of the 7 spokes after having a run in the gravel
So looking for recommends on brake upgrades and rims and tyres but not wanting to spend thousands.
Old Jul 21, 2014 | 05:45 PM
Paul_RS's Avatar
Paul_RS
You car is a 4x4 isn't it? If so you are buggered as there's nothing good that will fit behind RS 7 spokes.
Old Jul 21, 2014 | 06:14 PM
Old ford's Avatar
Old ford
Yes it's a 4x4, why won't anything fit behind the RS 7 spokes?
Old Jul 21, 2014 | 06:42 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
It's a wheel with very poor internal dimensions when trying to get bigger brakes inside, 2wd stands a better chance as the TRE position allows the disc to inset whereas the 4x4 requires a flat bell. Maybe run a big disc kit with your existing caliper??
Old Jul 21, 2014 | 06:50 PM
Old ford's Avatar
Old ford
Could I fit a 2wd calipher as I have been told these are better as they have more pistons.
Old Jul 21, 2014 | 08:10 PM
martysmartie's Avatar
martysmartie
No, due to the offset, but yes the fixed four pots are superior!
I believe some use the FRS bits.
Martin
Old Jul 21, 2014 | 08:26 PM
costina's Avatar
costina
Live long and prosper!!
DS 2500 pads and some national grooved discs which are TUV approved. Some goodridge lines and better fluid will help. Or its a big brake kit and new wheels
Paul
Old Jul 21, 2014 | 09:37 PM
Mark V8's Avatar
Mark V8
Why not use ST170 300mm discs with Mk3 Mondeo calipers ?
You will probably have to use washers to space the caliper centrally on the disc, but they should fit under your wheels easily enough
Old Jul 21, 2014 | 10:35 PM
jason_nike's Avatar
jason_nike
Ive been looking at your big disc kit you sell, very interested in one for my Sapphire 4x4.
Can the Focus RS calipers be used with this as well??
Would like to have larger calipers to match bigger discs, but car is only stage 1, so not big BHP.
And as OP says don't want to spend thousands as will have to do the 3 Door next afterwards
Old Jul 22, 2014 | 07:27 AM
Marc sierra's Avatar
Marc sierra
The ST170 discs do not fit, they foul the TRE as the offset is too big. The discs on the 4x4 need to be almost flat to not hit the TRE. As a result the calipers need to be quite far outward. This means that multiple pot calipers will not fit unless the wheels give a huge amount of clearance.
You can measure the clearance from the disc surface to the inside of the wheel spokes. For multiple piston calipers you will need at least 5.5 to 6 cm clearance.
Last year I looked into this a lot. What might be an option is using Peugeot 307 discs. They are 302 mm in diameter and 26 mm thick (standard disc is 24 mm). They PCD of the Peugeot disc is also 4x108, but the centre bore is slightly bigger. The total disc height is 34 mm compared to the standard 35.5 mm, so at least the disc will fit on the hub. The only 'problems' could be the centre bore being too big and the disc being too thick. But I think it would be doable to use these discs.
Old Jul 26, 2014 | 03:43 PM
Parky's Avatar
Parky
EBC redstuff pads,matching ebc discs, decent brake fluid and braided hoses is a strong setup on my 4x4
Old Jul 26, 2014 | 04:57 PM
Old ford's Avatar
Old ford
Anybody know if I can get bigger discs and use the existing calipersbehind the RS 7 spokes?
Old Jul 26, 2014 | 05:47 PM
Paul_RS's Avatar
Paul_RS
You can go to around 300mm IIRC. A mate had them on his 4x4 with softline 7 spokes. The kit was very similar to Reylands 308mm version.
http://www.reyland.co.uk/4x4-front-kits/
Old Jul 26, 2014 | 06:34 PM
cossie daz's Avatar
cossie daz
Can get a set of wheels on eBay , as long as straight doesn't really matter about the looks if cheap enough .
Some people fit frs Brembos , reyland do a bigger kit or capris port I think do a kit with Brembos ( eBay again )
Old Jul 29, 2014 | 10:37 PM
Mark V8's Avatar
Mark V8
I ran ST170 front discs on my XR4x4, can only assume the Cosworth 4x4 hubs are different
Old Jul 29, 2014 | 10:57 PM
JOHNDQ's Avatar
JOHNDQ
You would be mad to track on EBC even there Orange stuff dont hold up
Old Jul 30, 2014 | 02:34 PM
Marc sierra
Cosworth 4x4 hubs are indeed different. You can easily tell since the wheels on an XR sit much more outwards than on a Cosworth. For instance Escos wheels fit a Cosworth 4x4 fine, but on an XR4x4 they stick out a lot.
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
