2.2HDI failed emissions help
Old Jul 20, 2014 | 07:39 PM
andzz's Avatar
andzz
Default 2.2HDI failed emissions help
Hello all my 2002 c5 2.2hdi failed emissions ive been told to put some good additive in the diesel and go and blast it,, my HDI has no particle filter in and no cat but as i understand it themot cant detect no cat or DPF in a diesel, i understand the new rules that it must look like the DPF is there mine is all hooked up with no insides and the ecu mapped for no DPF.. iv been told this stuff is good https://www.dipetane.com/motorists/nct/ the guy said put a litre to half a tank and blast it, has anyone else used this stuff
thanks
Andy
Old Jul 21, 2014 | 07:35 AM
studabear's Avatar
studabear
You only need the dpf or cat for mot if the car left the factory with either.
If the cars servicing is uptodate then a good thrashing will normally help, a quality injector cleaner should help also.
Old Jul 21, 2014 | 07:58 AM
andy.v's Avatar
andy.v
its worth a try http://www.boards.ie/vbulletin/showt...p?t=2055151306.
Old Jul 21, 2014 | 08:18 AM
stevieturbo's Avatar
stevieturbo
C**t
Would obviously be helpful if you stated the exact reasons for fail. "Emissions" is rather vague.
Old Jul 21, 2014 | 10:03 AM
studabear's Avatar
studabear
If its a hdi then presumably its failed on excessive smoke?
Old Jul 22, 2014 | 05:36 PM
gingeRS's Avatar
gingeRS
Holding it at 5000rpm until smoke clears probably didn't do the engine much good
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
SMILER258
Sep 28, 2015 09:04 AM
oldskooldanrst
Sep 27, 2015 04:02 PM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
atm
Sep 7, 2015 05:39 PM
