The age old Cossie Spark Plug debate
Having googled this topic indepthly and read many threads on many forums I come to the conclusion there is no conclusion.
So in the none too distance future my 3 Door will be having its final mapping on the new BW 7670 EFR I'm running COP and I usually run it on IK31 but they don't last very long and at £40 quite expensive, currently it has some 071's in to bimble around in and they were only £8.
I always have the gap set to 0.8mm
So what's everyone views then? 071's IK27's IK31's or something else, also I wouldn't have a problem spending £100 on a set of plugs if they lasted
Rich
Rich
Last edited by Sonic Boom; Jul 19, 2014 at 10:02 AM. Reason: Woefully Bad Spelling Errors
PassionFords Creator
Having googled this topic indepthly and read many threads on many forums I come to the conclusion there is no conclusion. So in the none too distance future my 3 Door will be having its final mapping on the new BW 7670 EFR I'm running COP and I usually run it on IK31 but they don't last very long and at £40 quite expensive, currently it has some 071's in to bimble around in and they were only £8. I always have the gap set to 0.8mm So what's everyone views then? 071's IK27's IK31's or something else, also I wouldn't have a problem spending £100 on a set of plugs if they lasted
Rich
RichMost problems with iridium plugs come from excessive torquing of the threads and clowns putting copper grease on the threads on installation.
IK27 for me. IK31 are fine as long as there are no overly rich sections in the map and it doesn't spend most if it's life cold. They don't like rich mixtures as they are a very cold plug but if allowed to get hot they are fine.
I'd say it's probably does spend alot of the weekend in cold start.
So IK27's would alleviate this problem or at least reduce it?
Rich
I was using ik 31 which fouled up due to just moving car up the drive. So im now using 071. Think mine would b better suited to ik27
I always torque plugs to 30 nm as stated in the bible and i do use a little copper grease.
Whats the alternative to copper grease Stu? I know bmw have some kind of grease stuff they use. Using too much will affect resistance to ground .
Paul
Paul
great to know jay ,i get confused with all the different types.
i know of people who have been to tuners ,where the first thing they do is remove the plugs and throw them in the bin for their own choice plug
You could have butt plugs in your cars James cus they're never fooking used
No you need to warm the very cold plugs up each time you start.
It's easy all that is needed is to hold the revs at about 2.5k for about 20seconds you will hear the plugs clean and come up to temp.
Just constantly starting a cold engine and not doing this will foul plugs.
Mark
Mark
Mark
Mark
Mark
Mark
Rich
Copper grease on the threads prevents correct heat transfer from the spark plug threads into the cylinder head. This localises the heat in the spark plug and will lead to premature failure.
For initial mapping / mapping during cold starts etc I tend to favour a set of 071Cs - once i'm happy things are 90%+ complete - then drop a set of iridiums in for final power runs and leave them in.
This is it if your knocking plugs out its usually bad mapping ! I just find the denso plugs are prone to miss on boost past 2 bar and the price isnt much different to the champion 59c
The only thing I am certain of with any engine I use, the will never ever have champions anywhere near them.
Far too much history of them failing, and nothing to do with cold start or local use.
Everyone to there own run them in a 620 atw v8 ls1 engine for god knows how long as recommended by the builder never had a issue and run them in cossies fior years with no issue or a 071c but heard of loads of the denso's ends falling out melting ect
Mark
Not convinced with what I have found and tried them on w/s and olde age coil with different gaps
there a very delicate plug imo wouldnt fit them in a cossie never again but if you trust and like them then thats up to you mark
Mine used to misfire like fook with the champion plugs fitted to mine.It ran shite with the champion plugs in.
