Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
check engine light on
Old Jul 10, 2014 | 02:55 AM
ycfciloilo's Avatar
ycfciloilo
Exclamation check engine light on
i have 2007 1.8 ford focus. check engine light is on and i've been to ford garage in our place and i already spent so much replacing the parts. in just a month, they've replaced the fuel pump assembly, spark plugs, and 2 ignition coils. it temporarily erased the check engine light. but after 2 days of driving, again the check engine light comes out...not only that, the gas icon and the abs icon also light up on the dash board even though i have half full gas in the gas tank...what could be wrong? i am tired of going to and fro the ford garage because it's very expensive and they will just request the parts that they think should be replaced but that doesn't fix the problem...any suggestion? please. thank you
Old Jul 10, 2014 | 06:31 AM
oldford's Avatar
oldford
What are the fault codes currently in the engine and the abs?
If possible complete with number.
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
taylora1409
Aug 12, 2015 12:06 PM
Old ford
Jul 31, 2015 06:50 AM
