300mm rear brake upgrade
Old Jul 10, 2014 | 01:49 AM
Hellraiser's Avatar
Hellraiser
Default 300mm rear brake upgrade
As title where can i buy 300 mm rear brake upgrade? I have brand new 4x4 calipers so need bells, rotors and brackets!
Also do braided brake lines need to be any longer or are standards ok
Old Jul 10, 2014 | 10:31 PM
stevieturbo's Avatar
stevieturbo
C**t
I'm sure Reyland would sell something ?
Old Jul 10, 2014 | 11:29 PM
wildheart's Avatar
wildheart
http://www.reyland.co.uk/4x4-rear-kits/
Old Jul 11, 2014 | 01:24 AM
B13 JUS's Avatar
B13 JUS
Mt Motorsport sell a very good kit.
Old Jul 11, 2014 | 07:23 PM
Ridgey's Avatar
Ridgey
Compbrake also do a 300mm kit with everything you need.
They are overkill for a RWD Cossie, I'm having to run cheap standard pads on rear to prevent lockups, but my abs doesn't work
Old Jul 11, 2014 | 09:40 PM
wildheart's Avatar
wildheart
I had the same problem with rears locking up as soon as i put mine on too, Turned out to be one of the brake compensators, Sorted that and its now fine on track with race pads, so might be worth replacing on yours on the off chance
Old Jul 11, 2014 | 09:49 PM
Ridgey's Avatar
Ridgey
I'll look into it cheers
Old Jul 13, 2014 | 09:43 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
+1 for the mt motorsport kit. The quality is spot on. Even the brackets are threaded.
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
cossirob
Sep 3, 2015 09:17 PM
