A Couple Of Bolt Sets I've Made Up
Heres a couple of bolt sets i've made up, if you need anything let me know.
Cosworth 2wd Front Crossmember Complete Bolt Set
All Parts Are New, this kit consists off High Tensile Zinc Plated Parts.
The Kit will fit all 3dr And Sapphire 2wd Cosworth Models.
4 - Crossmember To Chassis
2 - Crossmember To Inner TCA
2 - Crossmember To Power Steering Rack
2 - Nyloc Nuts
10 - Washers
All Bolts are the Correct Length.
£13
Cosworth 4x4 Front Crossmember Complete Bolt Set
The Kit will fit all Sapphire And Escort 4x4 Cosworth Models.
4 - Crossmember To Engine Mounts Socket Caps
2 - Nyloc Nuts
14 - Washers
£15
Cosworth 7.5" Rear Diff To Beam Bolt Set
The Kit will fit all Sapphire And 3dr 2wd Cosworth Rear Beams.
1 - Long Bolt
4 - Short Bolt
1 - Nyloc Nut
6 - Washers
£8
Cosworth 7 - 7.5" Rear Diff Cover Bolt Set
This Kit will fit all 9" Cosworth Rear Diffs.
9 - Rear Diff Plate To Diff Socket Caps
9 - Washers
£10
Cosworth 9" Rear Diff Cover Bolt Set
The Kit will fit all 9" Cosworth Rear Diffs.
11 - Rear Diff Plate To Diff Socket Caps
11 - Washers
£12
2 - Nyloc Nuts
10 - Washers
£13
2 - Nyloc Nuts
14 - Washers
£15
1 - Long Bolt
4 - Short Bolt
1 - Nyloc Nut
6 - Washers
£8
9 - Washers
£10
11 - Washers
£12
Cosworth Rocker Cover Stainless Bolt Set
All Parts Are New, this kit consists of Stainless Steel Bolts.
The Kit will fit all Cosworth Models Rocker Covers apart from Escort Small Turbo.
20 - Stainless Rocker Cover Socket Caps
£6
Cosworth Rocker Cover Black Bolt Set
All Parts Are New, this kit consists Black Bolts.
20- Black Rocker Cover Socket Caps
£6
Cosworth Rear Trailing Arms Complete Bolt Set
The Kit will fit all Cosworth Rear Beams.
4 - Socket Caps, Arms To Beam
2 - Socket Caps, Arm To Strut
8 - Socket Caps, Arm To Bearing Carriers
2 - Bolts, Arm To ABS
6 _ Nyloc Nuts
22 - Washers
£14
Cosworth Front And Rear Anti Roll Bar Bolt Set
The Kit will fit all Cosworth Models.
6 - Socket Caps
2 - Nyloc Nuts
6 - Washers
£8
Cosworth Front And Rear ABS Bolt Set
4 - Bolts
4 - Washers
£3
£6
£6
6 _ Nyloc Nuts
22 - Washers
£14
6 - Socket Caps
2 - Nyloc Nuts
6 - Washers
£8
4 - Bolts
4 - Washers
£3
Cosworth Rear Callipers Complete Bolt Set
The Kit will fit all Cosworth Rear Callipers.
8 - Bolts
4 - Washers
£4
Cosworth Beam To Body Bolt Set
The Kit will fit all Cosworth Rear Beams, will bolt directly to the floor.
6 - Bolts
6 - Washers
£7
Cosworth 7 - 7.5" Rear Diff Mount To Floor Bolt Set
The Kit will fit all Cosworth 7 - 7.5" Rear Diff Mounts.
6 - Socket Caps
4 - Washers
£6
Cosworth Front Hubs Complete Bolt Set
The Kit will fit Sapphire 2wd-4x4 Escort 4x4 Cosworth.
2 - Bolts, Hub To Strut
2 - Bolts, Hub To ABS
2 - Special Shoulder Pinch Bolts
2 - Castle Nuts For Steering Rack
2 - Nyloc Nuts
2 - Washers
£8
The Kit will fit 3dr Cosworth.
2 - Castle Nuts For TCA
2 - Washers
£8
8 - Bolts
4 - Washers
£4
6 - Bolts
6 - Washers
£7
6 - Socket Caps
4 - Washers
£6
2 - Nyloc Nuts
2 - Washers
£8
2 - Washers
£8
Cosworth WRC - Group A Front And Rear Anti Roll Bar Bolt Set
All Parts Are New, this kit consists off,
8 - Black Socket Caps
8 - Black Washers
4 - Nyloc Nuts
£4
Cosworth WRC 6 Point Front Crossmember Complete Bolt Set.
All Bolts Are New, this kit consists off -
- 6 Bolts, Crossmember To Chassis
- 2 Bolts, Crossmember To Power Steering Rack
- 2 Bolts, Crossmember To Inner TCA
- 4 Socket Caps, Crossmember To Front Anti Roll Bar
- 4 Socket Caps, Crossmember To Front Brace
- 6 Nyloc Nuts
- 24 Washers
£24
Cosworth Group A 4 Point Front Crossmember Complete Bolt Set.
- 4 Bolts, Crossmember To Chassis
- 6 Nyloc Nuts
- 20 Washers
£20
Cosworth 2wd Sump Complete Bolt set
23 - Socket Caps
23 - Washers
£7
Cosworth 4x4 Sump Complete Bolt set
23 - Socket Caps
23 - Washers
£7
8 - Black Washers
4 - Nyloc Nuts
£4
- 6 Nyloc Nuts
- 24 Washers
£24
- 6 Nyloc Nuts
- 20 Washers
£20
23 - Socket Caps
23 - Washers
£7
23 - Socket Caps
23 - Washers
£7
Cosworth T5 Gearbox To Engine Complete Bolt Set
All these bolts are the correct Length.
10 - Bolts
10 - Washers
£13
Cosworth 4x4 Gearbox To Engine Complete Bolt Set
All the bolts are the correct Length, even the bolt that is required to hold the front diff bracket to the block.
6 - Bolts
7 - Socket Caps
13 - Washers
£16
Cosworth WRC Rear Cradle Bolt Set
- 2 Bolts, Cradle To Floor Pan
- 4 Socket Caps, Cradle To Boot Floor
- 6 Socket Caps, To Attach Link Bars To Cradle
- 2 Socket Caps, To Bolt Rear Bar To Cradle
- 10 Nyloc Nuts
- 20 Washers
£24
Cosworth 9" Diff To WRC Rear Cradle Bolt Set
- 1 Long Bolt, Through Diff Into Cradle Plate
- 4 Bolts, Through Diff Into Cradle Plate
- 2 Large Socket Caps, Through Cradle Plate Into Cradle
- 4 Long Socket Caps, Through Rear Bar Into Diff
- 1 Nyloc Nut
- 10 Washers
£14
Cosworth RS500 8 Injector Inlet Plenum Complete Bolt Set
This kit includes all bolts holding the plenum together even the nuts and washers to bolt the Plenum to the Cylinder Head.
30 - Bolts
8 - Socket Caps, for T.P.S and I.C.V and Throttle Body
11 - Nuts
41 - Washers
£12
10 - Bolts
10 - Washers
£13
6 - Bolts
7 - Socket Caps
13 - Washers
£16
- 10 Nyloc Nuts
- 20 Washers
£24
- 1 Nyloc Nut
- 10 Washers
£14
30 - Bolts
11 - Nuts
41 - Washers
£12
Cosworth BT Escort 4x4 Inlet Plenum Complete Bolt Set
14 - Bolts
10 - Nuts
32 - Washers
£11
Cosworth Sapphire 4x4 Inlet Plenum Complete Bolt Set
14 - Bolts
10 - Nuts
32 - Washers
£11
Cosworth Sapphire - 3dr 2wd Inlet Plenum Complete Bolt Set
17 - Bolts
11 - Nuts
36 - Washers
£11
14 - Bolts
10 - Nuts
32 - Washers
£11
14 - Bolts
10 - Nuts
32 - Washers
£11
17 - Bolts
11 - Nuts
36 - Washers
£11
A few more sets i've done today.
Cosworth 2wd Alternator Bolt Set
This Kit includes -
1 - Long Bolt, through Alternator into bracket.
3 - Medium Bolts, through Alternator bracket into Block
2 - Short Bolts, through Alternator and Water Pump (Adjuster Bar)
7 - Washers
1 - Nut
£6
Cosworth 4x4 Alternator Bolt Set
This Kit includes -
4 - Medium Bolts, through Alternator into Block
8 - Washers
1 - Nut
£6
This Kit includes -
7 - Washers
1 - Nut
£6
This Kit includes -
8 - Washers
1 - Nut
£6
Cosworth Power Steering Bolt Set
This Kit will fit all Cosworth Models, Kit includes -
3 - Socket Caps, 2 from bracket into block and the small 1 into the bracket
2 - Bolts, from bracket into block
2 - Bolts, for adjuster
2 - Bolts, from back of bracket into pump
3 - Bolts, from pulley into pump
12 - Washers
£10
Cosworth 4x4 Oil Pump Bolt Set
All Parts Are New, this kit consists off -
2 - Socket Caps, from oil pump into block
3 - Socket Caps, from pick up pipe into oil pump
1 - Bolt, from pick up pipe into block.
6 - Washers
£4
Cosworth 2wd Oil Pump Bolt Set
2 - Bolts, from pick up pipe into oil pump
5 - Washers
£4
Cosworth 7" Rear Diff To Beam Bolt Set
The Kit will fit all Sapphire And Escort 4x4 Cosworth Rear Beams.
2 - Long Bolt
2 - Short Bolt
2 - Nyloc Nut
6 - Washers
£10
12 - Washers
£10
6 - Washers
£4
5 - Washers
£4
2 - Long Bolt
2 - Short Bolt
2 - Nyloc Nut
6 - Washers
£10
Cosworth 4x4 Front Diff Bolt Kit
3 - Bolts, through diff into sump
1 - Bolt, through diff and engine mount into block
1 - Bolt, through diff bracket, through engine lug and into bellhousing.
5 - Washers
All the bolts are the correct Length.
£5
5 - Washers
£5
Are you still doing these bolt sets? If so can you let me price inc postage for complete 2wd front crossmember bolt set? ( the 1st picture you have on your post)
track.focus'd
Aug 12, 2015 05:53 PM
