SCS all ALLOY 2.2 800bhp YB plug and play unit
Old Jul 3, 2014 | 04:32 PM
c20tbo's Avatar
c20tbo
Default SCS all ALLOY 2.2 800bhp YB plug and play unit
Folks,
For sale as per title my Harvey gibbs SCS all Alloy YB 800bhp engine, plug and play unit.
This engine is as new, only had 3 hours running on brand new components
Its had a full top and tail from SCS with new shells, engine was absolutely spot on with no issues what so ever.
Will come complete with T6 2000 ecu, full dry sump system. And brand new race spec engine loom
Alloy block is approx 20kg lighter than standard block
SCS built YB, New Smith & Jones alloy tall block, 2.2 capacity, 10 long studs, oil spray jets, Extra long Arrow con rods, custom CP pistons with valve cut-outs, Arrow forged stroker crankshaft, Dry sump system with pace pump, heavily ported BIG valve head by Nick Waples, WRC multi layer head gasket, tubular manifold,custom turbo speced by SCS built by CR Turbos, custom inlet manifold designed and built by SCS, SCS spec high lift camshafts, Solid lifters, Isky double valve springs, 8 grey injectors, Pectel T6 2000 engine management, new quaife peg type pullys fitted, and a newly painted original blue rocker cover, runs coil on plug.
An absolute belter of an engine and capable of more if need be with a bigger turbo, same as AG focus.
I also have a new still in box correct flywheel available at an extra cost to suit this engine for a 7 1/4 clutch, clutch also available separately
18K ono for anyone seriously interested i could do installments but will require a hefty deposit, engine currently located at MK motorsport.
Harvey at SCS will be happy to answer any questions you may have, pics will be up loaded soon
Old Jul 3, 2014 | 04:38 PM
c20tbo's Avatar
c20tbo
Originally Posted by c20tbo
folks, for sale as per title my harvey gibbs scs all alloy yb 800bhp engine, plug and play unit. This engine is as new, only had 3 hours running on brand new components its had a full top and tail from scs with new shells, engine was absolutely spot on with no issues what so ever. Will come complete with t6 2000 ecu, full dry sump system. And brand new race spec engine loom alloy block is approx 20kg lighter than standard block scs built yb, new smith & jones alloy tall block, 2.2 capacity, 10 long studs, oil spray jets, extra long arrow con rods, custom cp pistons with valve cut-outs, arrow forged stroker crankshaft, dry sump system with pace pump, heavily ported big valve head by nick waples, wrc multi layer head gasket, tubular manifold,custom turbo speced by scs built by cr turbos, custom inlet manifold designed and built by scs, scs spec high lift camshafts, solid lifters, isky double valve springs, 8 grey injectors, pectel t6 2000 engine management, new quaife peg type pullys fitted, and a newly painted original blue rocker cover, runs coil on plug. An absolute belter of an engine and capable of more if need be with a bigger turbo, same as ag focus. I also have a new still in box correct flywheel available at an extra cost to suit this engine for a 7 1/4 clutch, clutch also available separately 18k ono for anyone seriously interested i could do installments but will require a hefty deposit, engine currently located at mk motorsport. Harvey at scs will be happy to answer any questions you may have, pics will be up loaded soon
Old Jul 4, 2014 | 08:12 PM
smiley's Avatar
smiley
Pm me what your looking mate please
Old Jul 4, 2014 | 08:14 PM
georgie1's Avatar
georgie1
18K ono
Old Jul 5, 2014 | 08:55 AM
c20tbo's Avatar
c20tbo
Pm replied
Old Jul 7, 2014 | 03:05 PM
c20tbo's Avatar
c20tbo
Bump for today
155lee
Oct 27, 2015 04:55 AM
mondeomark
Alloy wheels and ICE for sale
Sep 27, 2015 09:17 AM
`spotty
Sep 25, 2015 11:41 PM
ST-170
Sep 4, 2015 11:02 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
