Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Clutch pedal vibration while pressed down (2003, 1.8 tdci)
Old Jul 3, 2014 | 02:12 PM
tomtomtom's Avatar
tomtomtom
Default Clutch pedal vibration while pressed down (2003, 1.8 tdci)
Hello,
I have a 2003 TDCI 1.8 Ford Focus and when the clutch pedal is pressed down I can feel a tiny vibration through it.
I have read about DMF problems. Is it?
Car runs without problems. Can I drive it safely?
Old Jul 4, 2014 | 09:48 AM
uruk hai's Avatar
uruk hai
It "could" be the start of the DMF failing, when mine went the symptoms were.
Rattled on start up.
Rattled on switch off.
Vibration through the pedal when the clutch was pressed to the floor.
Rattled at the biting point.
Rattled when ever the car was allowed to labour in the first three gears.
The other thing worth considering is that when they start to break up the bits from the flywheel can drop into the starter motor and knacker that to !
Old Jul 4, 2014 | 09:52 AM
tomtomtom's Avatar
tomtomtom
Thank you very much! I will change it ASAP My car symptoms match yours perfectly.
Old Jul 4, 2014 | 10:40 AM
uruk hai's Avatar
uruk hai
No problem mate, glad I could help
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
Flateric_2002
Sep 15, 2015 08:41 AM
