Engine convertion
Hello I have a ford escort xr3i efi a thinking about changing to a 1.8 zetec I have read somwhere that you can fit this engine straight in with little fuss. I have read on a forum that you can use the efi inlet manafold by fitting a adapter plate which means it run ok is this right can anybody help
Yes thanks looked at that before that shows adding wire loom the bit I read says that you don't need to change loom just add plate to inlet and that's all you need trying to find out if that's right
Might as well go 2 litre in all honesty, 130bhp as opposed to 105 and oddly as it was never found in a hot hatch it can be cheaper to insure too. Pretty straight forward convertion too.
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
lockie
Jul 31, 2015 10:03 PM
