Exhaust fumes in car ?
Old Jul 1, 2014 | 04:16 PM
cossie daz's Avatar
cossie daz
Default Exhaust fumes in car ?
Hi all ,
I've been suffering from a exhaust smell in the car and last time out the car stank after I got back .
Any ideas of where it maybe coming in or anyone suffered from this
Old Jul 1, 2014 | 07:52 PM
martysmartie's Avatar
martysmartie
In the boot on either side there are vents, these should have a rubber insert in them. However, this can come out, which allows a greater airflow through.
Martin
Old Jul 1, 2014 | 09:02 PM
The Crocodile Hunter's Avatar
I have the same problem with mine. In my situation its coming from the joint between the down pipe and the turbo in the bottom (6 o clock) position and I cannot get it to stop.
Its as if the exhaust it preventing the down pipe from sitting square to the turbo? I've had it all off and refitted it all and it still does it, sometimes its worse than others but it never used to do it?
Been thinking about buying a flexi joing and cutting it into the exhaust to try and sort it?
Old Jul 2, 2014 | 12:22 AM
cossiestu's Avatar
cossiestu
My dad had that on his old Saff, was, as said above, the rubber flap in the rear.... It's not a breather sort of smell is it? Was thinking, might be the outlet on the breather tank, if you have one?
Old Jul 2, 2014 | 01:07 PM
L1AM_RS's Avatar
L1AM_RS
I have the same problem...
Pretty sure its where the exhaust housing meets with the elbow on mine....
Clothes smell slightly when you get out the car. Always have the window down also.
Should of really got the elbow machined flat
EDIT:
I also have a breather system...Wonder if its coming from there....
Old Jul 2, 2014 | 02:55 PM
cossie daz's Avatar
cossie daz
Thanks all
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
track.focus'd
Aug 12, 2015 05:53 PM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
blakey100
Aug 4, 2015 08:17 PM
Old ford
Jul 31, 2015 06:50 AM
