Sun visors fitment with a cage !!!!
Old Jul 1, 2014 | 03:42 PM
GINGExR2 T's Avatar
GINGExR2 T
Default Sun visors fitment with a cage !!!!
Anyone got any pics of how they have fitted sun visors into an S2 with a full cage???
I've converted my car to YB RWD, but using a standard safety devices bolt in 6 point cage, now the only difference in fitment is I had to remove and replace the 4 feet that bolt to the actual floor pan, the rear tubs are standard escort so I fitted the rear section 1st and then did the front 4 point, now there is no way I can get the visor back into there original position.
Is this a common issue or is it just mine
any pics of the visors fitted with a cage would be very helpful.
Ginger
Old Jul 1, 2014 | 04:29 PM
Oranoco's Avatar
Oranoco
Ginger
Since my cage went in the visors have been permanently down. Not my everyday car so just put up with it.
Old Jul 1, 2014 | 06:25 PM
muz's Avatar
muz
Wye Valley Hardcore
Mine don't fit. I was either going to just put a sun strip in, or make some little carbon sheets on small hinges attached to the cage.
Old Jul 1, 2014 | 07:19 PM
gus's Avatar
gus
Sun strip for me
Old Jul 1, 2014 | 07:23 PM
Sun strip, and a bit of window tint film lower down under the sun strip
Old Jul 1, 2014 | 07:48 PM
RSmark84's Avatar
RSmark84
Angle grinder, cable ties, and Roberts your mothers brother!
Did exactly that and my visors now fit onto the cage.
Old Jul 1, 2014 | 08:52 PM
russ rs's Avatar
russ rs
Sun strip way forward as cage manufactures advise not to drill them.
Old Jul 1, 2014 | 08:57 PM
turbotrev's Avatar
turbotrev
Same as Oranoco, when I had my RST I just fitted the cage in with the sun visors in the down position and then they stayed like that...
Cheers Paul
Old Jul 2, 2014 | 09:38 AM
GINGExR2 T's Avatar
GINGExR2 T
Glad it's not just me then looks like I've got something else to modify/make then :-/
Have you got any pics of how you did yours mate???
Ginger
Old Jul 2, 2014 | 07:07 PM
RSmark84's Avatar
RSmark84
Check out my cage/roof guide on the RSOC S2 section. There is/was loads of pics. May be some in my resto thread on there too.
155lee
Sep 6, 2016 11:10 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
