mk2 escort 4dr 2.0 c20xe tnt £4000 offers
Old Jun 29, 2014 | 12:49 AM
SGALLYWAG's Avatar
SGALLYWAG
Default mk2 escort 4dr 2.0 c20xe tnt £4000 offers
for sale is my mk2 escort 2.0 c20xe the shell is absolutely one of the best original shells you will find no doubt it is 32000 from new and NEVER WELDED and needs no welding.bought as a project it started life as a 1.6 ghia auto (so big tunnel), was owned by an old man who sat it up for 21 years and only had creased passenger doors so they got swapped out for clean ones.the engine is a 2.0 c20xe fresh bottom end new mains new oil scrapers and rings all brilliant compression the block was blasted and tested its running twin 45 webers type 9 gearbox mocal oil cooler 421 manifold e36 radiator the lighter flat type flywheel p150 alpha stand alone management chassis mounted custom hook on wcxm bias pedal box electric fan oil pressure (playing up) and water temp gauge front converted coilovers ae86 adjustable top mounts removable front slam rear adjustable gaz shocks anti tramp kit (welded scruffy) welded diff have a pan hard can chuck in aswell stripped out with side mounted bucket seats, harnesses, half cage snap off wheel (proper one) lines through the car kick panels 2.4 quickrack on poly mounts and door cards still in facet pump washer bottle in footwell 330mm suede steering wheel green tinted glass as standard. exterior is painted by roller in brown as I done this when I was a bit younger and never sorted, F.O.R.D square grill ghia front and back chrome bumpers m16 brakes as standard rolled arches 13x8 allycats with diamond cut lips all trim and badges removed. The car is taxed and tested 5 months tax and 11 months mot. I want £4000 but will take offers and part ex for a 3dr sierra base or whatever I'm located in sidcup kent my number is 07900561901 the car looks a bit scruffy but is solid as a rock everyone who sees it compliments the shell will try get pics but can't use photo bucket text or ring me and ill send um through have a fibreglass wing to go with it aswell may take swaps if your interested ring me as I don't get on here much cheers. really want a 3dr
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Ben26
Aug 27, 2015 08:56 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
