Prop doughtnut 3Door cosworth
Old Jun 24, 2014 | 08:36 PM
Harris.'s Avatar
Harris.
Default Prop doughtnut 3Door cosworth
Hi, has anyone got a picture of one fitted as I think mine has had it and should be getting my new one this week . Hopefully it will stop the vibration under the car .
Also whats involved in fitting it
Dave
Old Jun 24, 2014 | 09:01 PM
BRAMMER's Avatar
BRAMMER
The only thing on a 2wd prop are these items
http://www.burtonpower.com/propshaft...95-propcb.html
http://www.burtonpower.com/parts-by-...r-propcbr.html
Old Jun 24, 2014 | 09:06 PM
Harris.'s Avatar
Harris.
Cosworth parts for sale .
That's what i've got coming brammer . did you fit a new one? I'm hoping its stops the vibration I have on the car . I will change the gearbox mounts next but Just wasn't sure how its fitted
Old Jun 25, 2014 | 03:43 PM
tony66's Avatar
tony66
Default prop
sometimes worth slackening off the dominoes its fitted to and letting it find its own centre and re-tighten,has an issue years ago with this and unconverting a 4wd conversion back to 2wd on a sapph
Old Jun 25, 2014 | 04:45 PM
Harris.'s Avatar
Harris.
To a garage it is then
Old Jun 25, 2014 | 06:33 PM
BRAMMER's Avatar
BRAMMER
Simple you either split the shaft or theirs a bolt in one end and i think you can remove this to spilt the shaft and remove the centre bearing housing and replace the parts in minutes i think if it's Lee you bought it from hasn't worded it right it will be the parts i've listed above or you've bought a part not compatible to 2wd
Old Jun 25, 2014 | 07:08 PM
Harris.'s Avatar
Harris.
The parts you listed are the parts ive got coming mate .
Old Jun 26, 2014 | 04:56 PM
Harris.'s Avatar
Harris.
Any pictures of one fitted please ?
Old Jun 27, 2014 | 08:14 PM
Sinbad's Avatar
Sinbad
Had mine changed today at the garage whilst getting it mot'd, it came to £120 all in.
Old Jun 28, 2014 | 11:35 AM
Harris.'s Avatar
Harris.
Did it make a difference ?
Old Jun 28, 2014 | 12:11 PM
BRAMMER's Avatar
BRAMMER
It's just in the centre part of a rwd prop - we we fitted mine we removed the circlips and UJ but be careful as it's full of needle bearings
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
3doorcozmess
Sep 15, 2015 06:06 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
