Compression ratio
I have to order a MSD chip .
On the form i place to order the chip .
I have to note the compression ratio.
I have a set of CP pistons with cam cut outs.
What is the best way to find this ratio.
I have a set of old pistons that i could measure the bowl capacity on.
The car is a 2wd with a 4x4 head YB.
Thankyou
ok i have been on the calculaters.
31cc piston bowl.
46 cc head (this is going of a picture of a head and measurements on passionford)
91.3 mm bore x 91.3mm x pye(3,14) /4 x 76.9 stroke
guessed at 5cc head gasket
i am looking at 503 cc / 82cc =7.13:1
i would like to no the cc of a standard piston as they were about 8.1:1 standard.
If the bowl is up or below 31 it would help me become more confident with my results.
I have calculated 100 times and each site gives me a diffrent outcome.
mainly between 6.3 and 7.3.
Ok read the tech passionford and you add the 503cc to the tdc volume /by tdc.
This is why I had such low compression.
I have just the head cc and gasket to master and I can order my chip.
I have a bd14 inlet cam so the tuners will add this into the equation for non static compression .due to the cam being open longer.
Regards Craig
Thankyou
31cc piston bowl.
Regards Craig
Bump,
I am holding back before I order my chip to get it correct.
so if you no the cc of a head gasket or a 4x4 cylinder head ,skimmed .
Please return a cc.
Thankyou
Please return a cc.
Thankyou
