CG Motorsport clutch
Old Jun 21, 2014 | 03:40 PM
an-dy's Avatar
an-dy
Default CG Motorsport clutch
Hi,
My standard (genuine ford) clutch has started slipping badly after 300 miles so I am after an uprated clutch. Current spec is pretty average, fmic, exhaust, filter, -31 and 14psi. I would like a clutch that will good for 200+bhp/lbft to give me scope for the future.
Has anyone used CG motorsport clutches in 200+bhp rs turbos?
http://www.clutch-specialists.co.uk/..._p23368841.htm
I am likely to go with AP otherwise, even though the CP2000-8 kit is rated a 169lbft from searching it looks like its good for upto 230bhp/lbft?
Should I be looking at the CP2000-35 kit?
I did skim flywheel and will be skimming it again to be 100% sure everything is ok.
Old Jun 21, 2014 | 04:51 PM
studabear's Avatar
studabear
I've used a alcon 6 paddle and a standard pressure plate (luk) and it copes with mine really well.
Old Jun 21, 2014 | 05:33 PM
Chopshop85's Avatar
Chopshop85
Got an AP 2000-8 in my ERST. Been dealing with 195Ftlbs or torque for 15,000+ miles now.
Old Jun 27, 2014 | 04:11 PM
an-dy's Avatar
an-dy
I don't really want a paddle clutch so I'm swaying towards the 2000-8.
Chopshop85 - Did you do the pedal conversion and have your flywheel skimmed when you fitted the clutch?
Old Jun 27, 2014 | 06:00 PM
Chopshop85's Avatar
Chopshop85
Already had the pedal and haydraulic conversion done from a previous clutch.
IIRC you need to do with pedal conversion with the 2000-8, and no my flywheel looked fine so didnt need to be skimmed.
Old Jun 27, 2014 | 06:17 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
AP 4 paddle with standard cover and bearing for me. Works a treat.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
