Ford Rocam Engines
Somehow I seem to be getting hold of a Ford KA for free!
Not moaning, it's a solid 2006 poverty spec model with 70k on the clock.
I fancy having something abit rough and ready that I can abuse that will be a bit of fun too!
I thought for a quick and easy swap is chuck a 1.6 SportKa lump in it.
How similar are the 1.3 and 1.6 Rocam engines?
I'm hoping all the ancillaries will be a straight swap in which case swap the engines over, swap the ECUs and the chip in the key and away I go!
Also does anyone know if the engine and box will come out the top in ine piece? Or will I need to drop it out the bottom?
Bailes.
Bailes.
