Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
error code p0000
Old Jun 20, 2014 | 10:16 AM
afzal's Avatar
afzal
Angry error code p0000
Hi
I have 2 diesel focus cars, both 1.8tdci with the same eror code
p0000
Can someone help me as the cars refuse to start
Thanks in advance
• P0xxx Government required codes?????
Old Jun 20, 2014 | 10:23 AM
oldford's Avatar
oldford
P0000 does not exist. Zero usually means no fault code present.
What are you using to read the codes and waht are the model-years of the cars?
Old Jun 20, 2014 | 04:21 PM
afzal's Avatar
afzal
snap on verus
53 plate and 04
electronic injectors
changed diesel pump n injectors
runs on sniff, move it dies
error code p0000
Old Jun 20, 2014 | 05:09 PM
oldford's Avatar
oldford
I suspect a problem with the Snapon Verus.
I would get it on a proper Ford diagnostic machine.
Old Jun 20, 2014 | 05:21 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
They won't run unless you have coded the new injectors into the ECU.
Old Jun 20, 2014 | 08:53 PM
afzal's Avatar
afzal
they have been coded
Old Jun 20, 2014 | 09:11 PM
nicksaph's Avatar
nicksaph
have they been coded in firing order or cylinder order? i made this mistake first time i coded some with a snap on scanner.
i read it as being coded in cylinder order and it wouldn't run until i relised it should be coded in firing order i.e.
cylinder 1, injector 1
cylinder 2, injector 4
cylinder 3, injector 2
cylinder 4, injector 3
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
oilman
Sep 23, 2015 11:21 AM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
