T5 front oil seal
Old Jun 14, 2014 | 12:15 AM
BRAMMER's Avatar
BRAMMER
Default T5 front oil seal
Has anyone replaced one? If you remove the bearing carrier over the mainshaft to replace the oil seal do you have to mess on with end play or for just a seal replacement Just put back as it was removed with the same shim?
Also can this be done without having to remove any other section
Many thanks
Old Jun 14, 2014 | 09:38 PM
BRAMMER's Avatar
BRAMMER
Anyone?
Old Jun 14, 2014 | 09:39 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
I just removed it and replaced it when I fitted my centre push
Old Jun 14, 2014 | 11:15 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
If it's shimmed and your only changing the seal just put it back with the old shims. You would only needs to check shim heights if you was changing the bearings on that sharft
Danielbetty
Aug 28, 2015 08:01 PM
155lee
14
Aug 22, 2015 12:15 PM
C2 MAK
Aug 20, 2015 09:46 PM
st220kyle
16
Aug 14, 2015 06:13 AM
pegaz
Aug 12, 2015 07:30 AM
