various cosworth parts just in!!
2 X T34.63 TURBO £415 DELIVERED EACH (no pipes on them)
BOTH ALL GOOD SLIGHT PLAY SIDE TO SIDE BUT NORMAL
PF09 THROTTLE POSITION SENSOR £75
4X4 KONIS FRONT AND REAR NO SPRINGS £135
4X4 KONIS COMPLETE WITH LOWERING SPRINGS 30MM £175
4X4 FRONT BRAKE CALLIPERS £85
2WD MANIFOLD £75
4X4 MANIFOLD £85
2WD STARTER £45
2WD MONGOOSE EXHAUST £225
STAGE 3 LEVEL 6 ECU £175
2WD ENGINE LOOM £100
3 BAR MAP SENSOR £125
IGNITION AMP £25
AMAL VALVE £25
GREEN INJECTORS £125
STAINLESS MAP SENSOR BRACKET £20
TURBO TIMER £40
RS 500 INTERCOOLER LARGE CORE £150
91,2MM PISTONS AND RODS £150
BARE 205 BLOCK 91.2MM IN GREAT CONDITION £225 BARE!!!!!!!!!!!
GLOVE BOX CLIPS X6 £12.50 POSTED EACH!!
2WD MANIFOLD £75
4X4 MANIFOLD £85
2WD STARTER £45
IGNITION AMP £25
AMAL VALVE £25
TURBO TIMER £40
MORE PARTS HERE ON FACEBOOK
GO TO
Gary at RS Classics on Facebook as nearly all the parts are listed there also
GO TO
hI, a few parts needed
a pair of sliders for vented rear discs
a pair of 18mm 4x4 poly antiroll bar bushes
a pair of drop links for rear rollbar poly bushed if poss
the 4 braided rear brake flexi pipes
price including postage please
cheers gaz
cheers gaz
will check mate
best call me
hi, do you have the little plastic cover that holds the two sprung brass pins (for the horn on the steering stock )
if so how much posted to central Scotland ?
thanks
thanks
2x standard grind cranks that dont need a grind and ready to fit £425 each plus post
standard pistons and rods £150
1mm oversize pistons (like new) with rods £165
good standard bore 205 block £300
1mm oversize 205 block in excellent condition £300
