cosworth 3 door temperature query
Old Jun 9, 2014 | 11:41 AM
tony66's Avatar
tony66
Default cosworth 3 door temperature query
got a few questions about my 3 door..
the temp gauge goes only about a quarter maybe less up the gauge..
the car is fitted with a 200 block and i suspect thermostat hsg[3 bolts and a bleed screw] when first started and idling it gets warm both sides of thermostat. pipe into the water swirl pot[aftermarket] on the rhs i would have thought should remain cool until stat opens?
i would like to replace the stat and temp sender-i assume a 4wd stat will do it,but i need the older temperature sender to suit an 87 car[as it sends to the dash]
anybody got a link to wel, priced quality components..?
thanks
Old Jun 9, 2014 | 01:27 PM
Paul_RS's Avatar
Paul_RS
First thing i'd say is not to trust the dash temp gauge - they can vary lots from car to car. If you are worried try fitting an aftermarket gauge and check the temperature that way.
Old Jun 9, 2014 | 01:31 PM
Mark RS's Avatar
Mark RS
Just don't buy a stack one
Old Jun 10, 2014 | 07:12 AM
tony66's Avatar
tony66
Default temp
thanks folks-heater blows warm so at least it works
rad fans at front both work now i"ve replaced the fuse-but they are both through one relay instead of one each..so will alter that too.and will pop a new stat in with fresh coolant
Old Jun 10, 2014 | 07:41 PM
2Litre's Avatar
2Litre
Buy yourself a laser temp gun and compare for ref your interior gauge.
Cheers.
Tim.
Old Jun 10, 2014 | 08:15 PM
AndyPen's Avatar
AndyPen
The senders are cheap enough - I have no idea why they go off with age but mine did.
Old Jun 10, 2014 | 08:17 PM
tony66's Avatar
tony66
Default gun
Cheers.
Tim.
i have a laser gun-what temp should it find and where would be best to aim?
at say normal temp after a bit of stretching its legs...?
thanks
Old Jun 10, 2014 | 09:06 PM
2Litre's Avatar
2Litre
Your thermostat should open at 82 degree C . your should aim your gun at the elbow where the thermostat if located.
But don't be shy and take readings from your header tank/rad/turbo cooler(if present) this will allow you to build an overall picture of the efficiency of your coolent system and allow you to pinpoint problem areas.
It is a common issue with the 3 door re temp (overheating)due to the design of the head and it's proximity to combustion chambers. I live in Malta and all the pre-rads and coolers in the world cannot sort this out on this head design.
Keep an eye on your temps and save your car.
My Best.
Tim .
Old Jun 10, 2014 | 10:00 PM
tony66's Avatar
tony66
Default heat
thanks for that-was in malta a few years ago when you had a very hot summer-cant be very good for old turbo cars,got bad sunburn too
jessie_rs
11
Jun 3, 2019 04:57 PM
COSWORLD
Aug 14, 2015 07:40 AM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
Old ford
Jul 31, 2015 06:50 AM
