fiesta turbo cuting out on boost
evening all ive brought a fiesta rs turbo that im going to restore it pretty much std,
any way i found once it got to about 75 it would cut out on boost i found vacum on the dump valve was lose and all seem ok till to night on boost about 75 cut out again, and all way home very time brought on boost same thing any idea pete
Does it have a chip fitted? If so, check to make sure it is correctly fitted and use some tape to hold it to the ECU.
If there is no chip fitted then it sounds like it is over boosting and hitting the boost limit. Then the actuator or dump valve needs winding in.
It not chiped never has been std other than exhaust few hoses and shine bits lol it started few days a go , found lose hose to dump valve and sorted it out , done it last night and then started doing it very time I went on boost , going to stage one it where best to get chip seen few on e bay going to check fueling to
Thanks buddy I'm only looking to go 165 bhp I don't want to blow it to bits lol once I get it runing right going to fit a new camshaft and lifter as it noisey what every one else useing in std camshaft
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
Matt Baxter
Sep 16, 2015 08:30 PM
gchristophi
Aug 31, 2015 10:36 PM
paceo
Aug 27, 2015 12:45 PM
Escortdriver1
Jul 31, 2015 02:36 PM
