Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
2005 Ford Fiesta - remote central locking not going into learning mode
Old Jun 6, 2014 | 10:20 AM
kdavie86's Avatar
kdavie86
mk4 daft :P
Default 2005 Ford Fiesta - remote central locking not going into learning mode
Done loads of these before, but for some reason there's no chime/locks not cycling after cycling the ignition (tried 4, 6, 8 & 10 times - all no joy) - and remote is not being learned even after hitting buttons anyway? Checked C/L fuses, plugs on the GEM, 'door closed' sensors etc...
Any Ideas?
Old Jun 7, 2014 | 01:45 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
just giving this a Bump
All other electrics are ok and working as normal - so the GEM module seems okay.
Anyone have any ideas?
Old Jun 7, 2014 | 05:40 PM
Daveybob77's Avatar
Daveybob77
Stupid question, but are you sure it has the correct gem unit? Has the car always had remote central locking or are you trying to use a remote key for the first time?
Old Jun 7, 2014 | 05:51 PM
1980blakey's Avatar
1980blakey
Ive had it before where i do the ignition bit, then press the buttons on fob and then lock the door manualy then unlock with fob.
Old Jun 7, 2014 | 10:12 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
It's a mk6 Fiesta, on a 55 plate, so it should have remote central locking.
The car just had a basic 'transit style' non remote key at first. All keys were lost, and only had these keys available at the time. So I made the basic key, with the intention of returning the next day to do the remote one.
Took the chip out the first key, put it in a new 3 button remote key - cut it to match etc.
Just when I do the ignition on/off bit - It's just not going into learning mode?
Old Jun 8, 2014 | 06:34 AM
Daveybob77's Avatar
Daveybob77
Put the reg into this http://www.etis.ford.com/vehicleRegSelector.do and it'll tell you if it came with central locking from the factory, then you'll know if it should be working or not. Hope this helps!
Old Jun 8, 2014 | 07:50 AM
1980blakey's Avatar
1980blakey
Just drop the gem unit down its only 2 screws and it tells you on it if it was just alarm or remote alarm.
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Botts
Aug 13, 2015 04:16 PM
