Installing a 28/32 TDLM carb
Hey guys,
I am going to be putting a 28/32 TDLM carb onto a 1.6 CVH in a car which last week had an engine change. The old engine was a 1.4 cvh with the standard 1.4 Weber carb (28/30 DFTM)
The TDLM is different to the 1.4 carb and I have looked around on the net and found some information as to how I can install it, but not enough yet.
Labledcarb_zpsbd4cdbc1.jpg?t=1401899741
I just need help with where all of the pipes go.
I guess that
A = Fuel pipe
B = Anti run-on-solenoid valve (The 1.4 DFTM carb seems to have a fitting plug which I guess can plug right onto here)
C = I have no idea what this is?
D = Low pressure brake hose
E = I have no idea what this is either.
F = I guess this leads to the vacuum on the distributor?
Any help at all is very appreciated!
Thanks!
I guess that
A = Fuel pipe
Thanks!
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
