Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk5 1.4 Duratec timing Belt change Time
Old Jun 3, 2014 | 06:54 PM
Paul80's Avatar
Paul80
Default Mk5 1.4 Duratec timing Belt change Time
Hi all
I have a 2003 Fiesta with the 1.4 Duratec Engine and will soon be changing the Cam/timing belt and whilst I am awaiting delivery of some of the locking tools needed I have a couple of quick questions
1, I understand the best Timing Belt Kits are the ones sold under the name of Gates, is that correct and if yes anyone know the correct part number for their kit to fit my car.
2, I also understand that I will need a long bolt and nut to push the crank Pulley back on before it is bolted up to the correct torque with a new supplied bolt.
Anyone know the correct thread size and pitch of this bolt, I did read that it was a 12mm bolt but my local shop sells 12mm bolts in 0.5/0.75 & 1mm pitch threads, what do I need to get.
Thanks in advance with any help with this.
Paul
RUBY123
Oct 22, 2023 12:04 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Bailes1992
Aug 16, 2015 07:14 PM
taylora1409
Aug 12, 2015 12:06 PM
