Sold
Stack Dash. 8130P model, so has the usual trip, speed, rev. Also has Oil pressure, oil temp, fuel pressure, water temp, volts . Fully working, with all sensors ( including wheel speed sensor ) and a 4x4 oil filter relocator that has the oil pressure sensor fitted. is fitted to a saph surround with a Bright6 display ( indicator, oil pressure, battery, beam, handbrake lights ). Not the best fitting in the surround, but served its purpose £650 Sold
Stack Wideband AFR. Good sensor which has covered under 5000 miles. The U shaped bracket is missing though, still fitted fine in my pillar pod though. £offers Sold
Display not functioning properly. Details to follow.
SPA Dual Boost and EGT. Has new EGT probe. The U shaped bracket is missing though, still fitted fine in my pillar pod though. £offers Sold
pm sent
Dual 52mm pillar pod. Abit of a crack at one end but i never really noticed it. £30
Sorry chap, I was sure I had replied.
Someone had asked for it before you and agreed to have it, but when I tested it again before packing it up, one of the numbers has gone dim on the display :-(
Just received my SPA gauge this morning. Excellent communication, super fast delivery and packaged extremely well - thank you for an excellent transaction
top bloke.
Scott.
Scott.
Im 99.9% sure thats what it was. But the chap has got it now, fitted it and its working as it should, minus a dim digit.
155lee
Oct 24, 2015 11:11 AM
