Stage 3 200 Block Cosworth Gasket Set Advice
Old May 27, 2014 | 01:15 PM
Lowson's Avatar
Lowson
Default Stage 3 200 Block Cosworth Gasket Set Advice
I've stripped my YB down and I'm looking to replace all gaskets.
Mainly looking for advice on what kind of head gasket to use. Running stage 3, don't know what other info might be worth noting for choosing.
Ideally I'd like to buy a full kit of all gaskets and seals but if have to buy a seperate head gasket due to spec and then other gaskets and seals, so be it.
Old May 27, 2014 | 01:29 PM
jamie956's Avatar
jamie956
Mainly looking for advise on what kind of head gasket to use. Running stage 3, don't know what other info might be worth noting for choosing.
Group A head gasket and the rest Cometic,
http://www.mattlewismotorsportonline...7_1622808.aspx
Old May 27, 2014 | 01:51 PM
rog's Avatar
rog
I used a group a gasket yb0611 I think it's called, victor reinz, I got them all from wood ford garage
Old May 27, 2014 | 04:45 PM
L1AM_RS's Avatar
L1AM_RS
I'm using a VR group A gasket with cometic / ford gaskets on my freshly rebuilt YB. No leaks as of yet *touch wood*
Old May 27, 2014 | 05:31 PM
siscossie's Avatar
siscossie
3-door moonstone
Group A head gasket and cometic for the rest done ok for mine
Old May 27, 2014 | 05:39 PM
cossie330's Avatar
cossie330
Ive just used a small turbo escort cosworth head gasket and cometic gaskets from Matt Lewis, also got genuine headbolts with the set and genuine valve stem seals
Old May 27, 2014 | 10:00 PM
Lowson's Avatar
Lowson
Thanks for the replies guys, VR Group A looks like the way to go.
Old May 29, 2014 | 09:15 AM
cossie moon's Avatar
cossie moon
Durham RSOC member
If 4x4 make sure you use proper sump sealer ford sell good stuff iv used it dozens of times on all sumps and never had a problem its actually made by loctite but cant remember the number as i think it may be cheaper of line under loctite name not ford. Dont use cheap silicone or anything like it because it will leak once you have ran it in and turned boost up.
Old May 30, 2014 | 03:29 PM
Lowson's Avatar
Lowson
It's a 2WD moon, I have heard that Nissan sump sealer is meant to be the dogs danglies... Will have to do a bit of research. Will be a wee while before I'm back on it.
big_Rad
Sep 15, 2017 09:36 AM
JasonPD
21
Aug 20, 2015 07:36 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Aug 14, 2015 07:29 AM
Zoggon
Aug 10, 2015 10:39 AM
