Ford Escort RS Turbo 88 Spec
Old May 26, 2014 | 07:31 PM
Glenn H's Avatar
Glenn H
Default Ford Escort RS Turbo 88 Spec
Ford Escort RS Turbo 1988 E Reg
M.O.T September 2014
Tax June 2014
£2500
Having to have a clear out with nipper on the way and some toys need to go as I'm not getting to finish my camper or cossie.
Just had full engine rebuild minus pistons with all receipts, for Santa Pod next week as my cossie isn't finished. This is a good base for restoration! chassis wise it had £700 worth of new floors, sills, and chassis rails fitted for M.O.T, the only thing that lets it done is its aged interior and body. But on the plus side the car has only covered 92k going by M.O.T.s and Gov website, and it still has the working ABS System not bad.
I have just fitted stage two T3 Turbo and Turbo Systems ECU car is currently running at 10 psi of boost, i have checked with my A/F/R gauge and everything fueling spot on.
I will get more detailed pictures and I will be taking it to Santa Pod next weekend.
[IMG][/IMG]
http://s989.photobucket.com/user/Superted82/library/
Old May 26, 2014 | 08:44 PM
ant123456's Avatar
ant123456
What issues are there with body and interior?
Old May 26, 2014 | 08:49 PM
Glenn H's Avatar
Glenn H
Slight rust on rear panel under lights, at the back of the battery tray and a few pin dents, inner lip on rear screen on tailgate and a full respray to make mint. Interior 88 spec but sagging same as cards and roof lining. Pictures are before i rebuilt 2 weeks ago.
matman
Sep 9, 2015 05:45 PM
dodge8283
27
Aug 19, 2015 08:42 AM
adriansaleem
Aug 1, 2015 09:28 PM
