Starter motor issue
Old May 25, 2014 | 01:27 PM
jamie956's Avatar
jamie956
Default Starter motor issue
I have a 1.8d connect starter on my YB been turning engine over fine for the last two weeks while trying to get it started, come to it this morning and nothing. Been fucking about with ECU problems finally got that back and now this.
Put the meter round it and with just the battery lead on im getting 12v on the starter terminal, starter switch circuit working fine so guessing the solenoid is dead.
Old May 25, 2014 | 03:29 PM
cabriolet's Avatar
cabriolet
put a screwdriver across the 2 terminals with 13mm nuts on them if the motor spins the solenoid is duff if it doesnt spin you have probably burnt it out [bet the starter is motorcraft]
Old May 25, 2014 | 03:56 PM
slammedorion's Avatar
slammedorion
Battery is flat if its only reading 12v
bobsworth
77
Mar 24, 2016 09:30 PM
Mark_
14
Jan 16, 2016 05:27 PM
A.t.p
Oct 23, 2015 07:54 PM
SMILER258
Sep 28, 2015 09:04 AM
marky_g
Sep 12, 2015 04:26 PM
