gaz coilovers
Old May 22, 2014 | 07:44 PM
eel-roy-t5r's Avatar
eel-roy-t5r
Default gaz coilovers
hi all , were is the best place to buy gaz coilovers , I want to deal with some1 who has experience with the different spring rates and whats best for my needs etc etc.
also whats the difference between the gaz golds and the standard gaz ,apart from the price
cheers
Old May 25, 2014 | 09:11 AM
oohogwash1's Avatar
oohogwash1
I called Gaz direct, they were fine to help.
I bought Gaz gold, it was not that much more.
I have found that the ability to adjust ride height on all Gaz shocks requires some thought as the ones I got dont have the extra bits for easy height control that others have. They might be better these days.
Old May 25, 2014 | 10:02 AM
KSA-Cossie's Avatar
KSA-Cossie
I got a cracking deal on my Gaz golds from Dan at rapid ford
Old May 25, 2014 | 10:26 AM
eel-roy-t5r
cheers lads , what spring rates are yous using
cheers
Old May 25, 2014 | 12:08 PM
KSA-Cossie's Avatar
KSA-Cossie
350lb front 180lb rears
Old May 31, 2014 | 04:16 PM
Danielbetty's Avatar
Danielbetty
450lb front 250lb rear
Old May 31, 2014 | 06:09 PM
eel-roy-t5r
okay lads cheers for the feed back , the car is a 4x4 so slighty heavier than the 2wd.
danielbetty that's a big difference on the front and smaller increase on the rear , is yours set up for track or just the road , I don't want the car to be to stiff that is skips about
Old May 31, 2014 | 06:57 PM
Danielbetty
Road mate don't skip at all handles really well,we'll as good as an old sierra can
Old Jun 1, 2014 | 10:22 AM
eel-roy-t5r
cheers , and is that with the damper on its softest settings
Old Jun 2, 2014 | 08:24 PM
Danielbetty
Not it's softest setting about 4 clicks at present
Old Jun 3, 2014 | 03:19 PM
eel-roy-t5r
cheers for the info bud
Old Jun 3, 2014 | 10:01 PM
boost mad's Avatar
boost mad
I ran 325 on the front and 180 rear, on a 4x4 saph
Old Jun 4, 2014 | 02:27 PM
eel-roy-t5r
a spoke to dan and he advised 400/450 on the front and 180 on the rear , haven't ordered any yet as I need to find some were local to me that can corner weight the car
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
lime
Sep 25, 2015 06:56 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
