Long life or Powerflow?
No comment or experience of Longlife. PowerFlow are total shit for anything more than nailing a big pipe to the back of your first car. Making an exhaust yourself from toilet roll tubes and sticky tape would not only be of better quality but likely last and perform better too.
Ice direct are ok from what ive heard but quite expensive, worth going in for a quote i'd say. Personally i use and friends have used pp tuning in louth, very reasonable and top quality work using mandrel benders ect. I live in peterborough same as you but made the journey there for the above reasons. Its about 1.5-2 hrs
i used to make longlife exhausts and they are far better quality than powerflow in every way though still not quite as good as a mandrel bent system. longlife have good quality control as well if a fitter isnt up to the job they are binned off and replaced quickly
sridgett
Oct 1, 2015 07:30 PM
