'Spec' stage 2 st170 flywheel and clutch directly replace dual mass SOLD!!
I'm selling an Spec stage 2 complete setup flywheel and clutch(Kevlar disc with steel backing) a direct replacement for the dual mass setup on an st170. Cost a fortune to import from the states. Done 25,000 miles only, melted a valve on engine back in the day and this has sat on a shelf ever since.
Plate, clutch and flywheel faces are superb, so much so original manufactures facing off marks still visible on pressure plate, there is no wear on matting surfaces!! Centre spline aperture on clutch unit does however have engagement marks.
http://www.specclutches.com/618909/s...s-sf30s-537795
http://www.specclutches.com/651542/s...s-sf002-523795
£450 collection only West London
Might be worth ebaying it fella posted would probably help sell aswell if I had that money spear would snap ya arme off
dont supose u would take a cheeky bid on it ?
jessie_rs
11
Jun 3, 2019 04:57 PM
