inlet valve escort rs turbo
Old May 14, 2014 | 08:37 AM
ro33's Avatar
ro33
Default inlet valve escort rs turbo
Do you know that quality is?
http://www.ebay.es/itm/Ford-Escort-F...349e933&_uhb=1
and these?
http://www.burtonpower.com/parts-by-...cvh-cv370.html
want larger valves for inlet, but I know of no brand
Old May 14, 2014 | 02:23 PM
Canada1's Avatar
Canada1
Both of those valves are OK.
However, those valves are stainless steel without hard chromed valve stems.
These valves require manganese bronze type valve guides which wear well with the softer surface of the stainless valves.
If you are using the factory cast iron valve guides I would not use stainless valves.
Accelerated valve stem wear will happen.
Old May 14, 2014 | 06:41 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As Perry says.
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
