2wd for pots to fit rears anybody done this ?
Just been having a think and wondered if anyone had tried fitting the front original 4 pot calipers to the rear of a saff , as I found them to be a very good brake when I had them on the front
Did it about 15 year ago, great braking until you dip the clutch (2wd) then rears locked up.
Putting a restrictor in the line, had to take off most of the rear pressure, really negated the job of fitting them in the first place
i had advice from mike rainbird about fitting 4 pots to the rear of my 2wd saff and he told me very clearly i would end up in a ditch lol
he said its ok on a 4wd as the wheels are linked mechanically , but on a 2wd you firstly would have to fit a bias valve and you would have to bias it that much to the front that it would leave the 4 pots doing little or nothing on the rear .
james kiely
Aug 28, 2015 08:58 PM
155lee
Aug 14, 2015 11:21 AM
track.focus'd
Aug 12, 2015 05:53 PM
lockie
Jul 31, 2015 10:03 PM
, so have had to run bog standard cheap rear pads now, no point in going bigger calipers.
