Cosworth ABS sensors
Old May 11, 2014 | 04:05 PM
daviddunlop83's Avatar
daviddunlop83
Default Cosworth ABS sensors
Are the ABS sensors the same for both 2wd and 4wd Sierra cosworths on the front?
Part number:- 6175345
Old May 11, 2014 | 04:24 PM
charlie luciano's Avatar
charlie luciano
Iirc they are different
Luciano
Old May 11, 2014 | 04:28 PM
stephenbatey's Avatar
stephenbatey
Round (2wd) or squared (4x4) connector iirc.
Old May 11, 2014 | 04:39 PM
daviddunlop83
The ones I have are round connectors but def fit 4x4 :s
Old May 11, 2014 | 04:42 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
It's only the late 4x4s that differ. Most are round plugs, the later ones are oval.
Old May 11, 2014 | 04:45 PM
All the saffs and 3drs are the same. The escos ones are different.
Old May 11, 2014 | 04:48 PM
DixieTheKid
Pick-up P100 Power!
Think some of the later 4x4 saph had them too Glenn. A bought a complete rear beam out of a late saph and they where oval.
Old May 11, 2014 | 04:52 PM
I thought it was just the escorts that were different. My Jreg 1991 saff has the old style round plugs.
Old May 11, 2014 | 05:45 PM
daviddunlop83
My friends 93 has round plugs too iirc
Old May 11, 2014 | 06:01 PM
Mark V8's Avatar
Mark V8
I'm looking at buying a pair from David.
Here's a pic of my connectors
I did not know if the different 2WD and 4WD part numbers were to do with the amount of teeth on the abs ring
Microcat info is:
2WD Finis 1654336
4WD Finis 6175345
Thanks for any info
Old May 11, 2014 | 06:24 PM
daviddunlop83
Here is ones I have,
Old May 11, 2014 | 07:00 PM
Paul_RS's Avatar
Paul_RS
Microcat info is:
2WD Finis 1654336
4WD Finis 6175345
Thanks for any info
The difference may be the wire length. My loom (4x4) extends further towards the front of the car than in the photo you've put up.
Old May 11, 2014 | 07:18 PM
I cant get over the price of them new.
Old May 13, 2014 | 06:13 PM
Mark V8's Avatar
Mark V8
Anyone know 100% if the 4x4 ones are compatible with the 2WD set up?
I do not want to buy a pair that give me problems when my car eventually goes back together
Old May 13, 2014 | 06:22 PM
Mark RS's Avatar
Mark RS
Yes there compatible,I put a 2wd one in my 4x4
Old May 13, 2014 | 06:46 PM
Im sure ive got a 2wd front sensor on my 4x4.
Old Feb 1, 2015 | 03:10 PM
costina's Avatar
costina
Live long and prosper!!
How much !!!!!! even for a pattern part lol
original
Apr 28, 2026 05:20 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Tim Wharton
Aug 30, 2015 05:46 PM
rdvil
Aug 15, 2015 12:11 PM
Aug 14, 2015 07:29 AM
