4X Reconditioned/unused Garrett T25 Turbos. 250Bhp Capable Each- £250 Each
As title really. These-
Proven at 250bhp each. T2/T25 flange, usual T25 style 2bolt compressor flanges and 4bolt outlet flange.
These were picked up from a turbo builder, and at first look we presumed they were brand new as they're totally mind, but you can see the slight cracks around the wastegate penny washer on some, just like all used T2/T25/T28/GT28 turbos, so they're obviously reconditioned turbos rather than new, but as you can see, they look great.
.54 turbine housing, so fast spooling, ideal for small engines wanting good response as well as 200bhp+.
51mm compressor wheel with 40mm inducer (69trim)
47mm turbine wheel with 39mm exducer.
Water and oil cooled.
Can come with an actuator too if you like, they're certainly not new or recon, but I'm 90% sure they're intended for these turbos (look about right and came with them) and you could use the bracket if nothing else.
£250 each. Plus £15 posted (fully tracked) within mainland UK.
155lee
Sep 6, 2016 11:10 AM
dirty-diesel
Sep 29, 2015 07:25 PM
