sapphire cossy seat runners
Old May 8, 2014 | 08:11 PM
killa_paul's Avatar
killa_paul
Default sapphire cossy seat runners
How difficult is it to seperate a recaro leather seat from its runner ...
photos if possible please
Than
Old May 8, 2014 | 08:15 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
about 8 bolts 10mil
Old May 8, 2014 | 09:20 PM
TrevCos's Avatar
TrevCos
Depends on whether you're talking drivers or passenger, because the drivers side is height adjustable, passenger side isn't. Drivers side comes off as a full frame apart from the height adjuster bar, the passenger side comes off as two separate runners connected by a central link bar.
You might find you need some torx keys too.
Old May 8, 2014 | 09:33 PM
killa_paul's Avatar
killa_paul
i need to do both
Old May 8, 2014 | 09:37 PM
mk2grp1's Avatar
mk2grp1
10 mil bolts and t40 torx on drivers height bar
Old May 8, 2014 | 09:40 PM
TrevCos's Avatar
TrevCos
They're not difficult really. Have a crack. The drivers one is a bit more of a fiddle than the passenger one but neither are that bad.
As I remember on the passenger one you just have to slide the runners back and forth so you can get at the bolts that are actually hidden inside the runners front and back.
On the drivers side you have to unbolt the front height adjuster bar from the rest of the frame by undoing the two bolts that go in through the sides of it, and the back of the frame has two similar bolts. Then remove the adjuster bar from the seat.
S3an
Sep 26, 2015 11:39 PM
Kam B
Sep 24, 2015 10:40 AM
nikki.n.tom
Sep 15, 2015 08:20 PM
S3an
13
Sep 13, 2015 10:01 AM
cambo205
Ford Fiesta
Sep 6, 2015 07:45 PM
