mfi rs turbo c0
Old May 5, 2014 | 11:32 AM
ro33's Avatar
ro33
Default mfi rs turbo c0
% co that I believe necessary, in 18psi boost ?
How I can get more fuel? in mfi
cold start injector?
it has: -31 actuator, chip ecu, kent kams cvh35k, wossner pistons
Old May 6, 2014 | 06:08 PM
tlr_rst's Avatar
tlr_rst
someone with more knowledge will be along but about 3% Co and with more fuel from the little black box onside of the metering unit. taking it apart and small screw in there will adjust fuelling
Old May 8, 2014 | 09:46 PM
ro33's Avatar
ro33
How adjust fueling? How much I have to tighten the screw?
thanks
Old May 8, 2014 | 10:31 PM
studabear's Avatar
studabear
You need a wideband lambda sensor set up so you can monitor the air fuel ratio.
half a turn on 1 car will not be the same adjustment on the next car
Old May 9, 2014 | 01:16 PM
ro33's Avatar
ro33
I had thought., Which would you recommend?
Old May 9, 2014 | 07:32 PM
Red_bull's Avatar
Red_bull
Take it to a tuner unless you know what you are doing!
stevierob
Sep 7, 2015 07:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
