Which High Independence Injectors?? Best Spray pattern??
Thinking of going aftermarket ECU with high independece injectors, I know with the low independence ones Siemens have a preferred spary pattern to Bosch.
Does anyone know a good high independence injector to use in a cosworth engine with a good spray pattern??
Speak to your mapper as he will need to know as he may not want to map one or the other due to not having a base map.
Mark
Havent got one yet, the engine is still in bits
Thanks for the info, just deciding what to do, whether to keep the P8 or go aftermarket, just all boils down to the same thing..... how deep are my pockets lol
You'll look silly asking for independence injectors....
Sort the Ecu direction out first then work out which injector to use.Which means you have to sort who will map it first then ask what Ecu to use.
