master cylinder
Old Apr 29, 2014 | 06:42 PM
55rsturbo's Avatar
55rsturbo
Default master cylinder
hi all could you tell me if you use a different master cylinder when using a bigger brake upgrade, i am using cosworth 4x4 discs and calipers. abs has been removed and the master cylinder at the moment has the four outlets, does every one find this ok, i seem to have a lot of travel befor it seems to do any thing. i would be gratefull for any advise. cheers frankie
Old Apr 29, 2014 | 07:18 PM
I have mk1 focus rs front brakes and focus rear disc conversion ,abs removed ,i am still using my rs turbo spec 2 outlet master cylinder 25mm with no problems ,the 4 outlet master cylinders are the smaller mm off the lower spec models
Old Apr 30, 2014 | 10:19 AM
RSmark84's Avatar
RSmark84
Keep the m/c from the RS turbo and use a res. from a Fiesta, Thus reducing the outlets down to 2.
Old Apr 30, 2014 | 10:39 AM
haz87's Avatar
haz87
I think he means 4 M/C outlets not the resovoir
Old Apr 30, 2014 | 05:24 PM
55rsturbo's Avatar
55rsturbo
hi thanks for reply where can i get a 25.4 master cylinder please. cheers frankie
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
