Re-fitting saph door
Old Apr 28, 2014 | 08:18 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Default Re-fitting saph door
Is there any method to re-fitting a saph door as I'm having trouble getting my driver door back on properly. I put the door on and lined up the panel gaps but it never sits right once the bolts are tightened.
Is there a method to re-fitting?
Cheers.
Old Apr 28, 2014 | 08:29 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
I use wedges of wood as the spacers and fit the 13mm's on loosely till your happy with it, if your still having issues the you may find something is bent
Old Apr 29, 2014 | 09:23 PM
Jimboxr4x4's Avatar
Jimboxr4x4
Cheers, got it sorted by using a jack to support the door and gradually adjust the height until it was right. Was pretty easy way if your doing it on your own.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
gcfcos
88
Sep 15, 2015 03:48 PM
RSmark84
Sep 13, 2015 01:29 PM
