would 2wd springs fit 4wd sierra cosworth
Old Apr 27, 2014 | 09:37 PM
paalrosen's Avatar
paalrosen
Default would 2wd springs fit 4wd sierra cosworth
I see that some springs are made for both cars (APEX) if i remember correctly.
Looking for springs to my sierra 4wd, there is no one with tuv papers, we all know.
Eibach has black springs that look anonymous, which is good.
they have a set for 2wd sierra with right axle weights to fit the 4wd.
but will they fit?
Old Apr 28, 2014 | 12:17 PM
martysmartie's Avatar
martysmartie
They will physically fit, however, it will probably sit too low, as the 4x4 is higher. The ratings are probably different as well.
Martin
Old Apr 28, 2014 | 08:57 PM
Marc sierra's Avatar
Marc sierra
I believe the original springs are the same for 2wd and 4x4 sapphs. The Ahmed Bayjoo springs are also the same for 2wd and 4x4.
Old Apr 29, 2014 | 10:20 PM
martysmartie
Are you sure, as the 4x4 has a different ride height?
Martin
Old Apr 29, 2014 | 10:26 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
they will physically fit but there will be ride height issues on the front
rears will be fine
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
dal3door
Aug 13, 2015 06:55 AM
Harryh24
Aug 11, 2015 07:48 PM
martynhomer01
16
Aug 4, 2015 09:55 PM
