Urgent help does my 2009 ford focus zetec a have canbus?
Hey guys just joined as I need some help quickly I have fitted a tow bar to my 2009 ford focus zetec s 1.6 petrol
I am wiring it up tomorrow but need to know if the car runs can bus as I will need a relay or if it does not then I know it's going to be straight toward
Do any of you guys now if it has or not?
Thanks
Thanks
All modern cars have canbus, just depends on what you are trying to do is on the can network.
Usually there is a plug behind one of the boot trim panels that you plug the tow bar loom into.
Awsome I have a bypass relay here invade but for the past two days I have been failing at getting power to the tow bar socket however I wired it up the old way today and worked straight but wanted to make sure that it was ok to do so before leaving it that way as don't want to blow and electrics
