Rs Turbo MFI inlet studs
Old Apr 25, 2014 | 01:24 PM
dajafu2002's Avatar
dajafu2002
Default Rs Turbo MFI inlet studs
Does anyone know where i can source some the studs that go in to the head, on the inlet manifold side. I do have an old head with new studs, but I can't seem to remove them with mole grips.
Old Apr 25, 2014 | 01:33 PM
haz87's Avatar
haz87
Use two nuts, one tightened against the other to remove the studs.
If not, they're nothing special, any fixing/fastener place will have them
Old Apr 25, 2014 | 01:38 PM
haz87's Avatar
haz87
To clarify the 2 nut method:
Run the two nuts onto the thread until the stud is sticking out of the second nut; tighten the two nuts against each other (two spanners in opposite directions) until they are locked, then, using the first nut, you should be able to unscrew the stud. Can take some force (tightening against one another) to crack the stud loose
Old Apr 25, 2014 | 02:52 PM
dajafu2002's Avatar
dajafu2002
I will give it a bash tomorrow, thanks
Danielbetty
Oct 3, 2015 06:01 PM
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
atm
Sep 1, 2015 04:56 PM
IAN RS2k
Aug 18, 2015 07:51 PM
